Hi, I try to convert a .CR2 file to JPG, it converts to JPG, but it does not respect the dimensions of the original photo.
The dimensions of the .CR2 file are: 5496x3670, and the JPG file has lower dimensions: 2748x1835.
Why it does not respect the same dimensions when it makes the conversion, is it necessary to configure something?
I attach an image if you want to check it.
I leave a link, because it does not allow me to attach the file with CR2 extension
https://drive.google.com/file/d/1kjuwC5 ... sp=sharing
Thank you.
XnShell - Convert CR2 to JPG does not respect the dimensions.
Re: XnShell - Convert CR2 to JPG does not respect the dimensions.
Hello xnview, there is something new about this problem ?
