Question to: how does XnViewMP write metadata
herb
Post by herb »
From versions of XnViewMP previous to 1.4.0 I know that Adobe XMP-sdk was used to read/write metadata into images.
With version 1.4.0 XnViewMP also uses ExifTool.
Is with version 1.4.0 only ExifTool used to write metadata?
Or does XnViewMP still also use XMP-sdk?
In case of both are used, for which cases are they used.
Is there an option that tells XnViewMP only to use ExifTool?
Thanks for your answer in advance.
Best regards
herb
Re: Question to: how does XnViewMP write metadata
herb wrote: Thu Dec 29, 2022 12:00 pm Is with version 1.4.0 only ExifTool used to write metadata?
ExifTool is only used to write XMP as embedded in RAW files
herb
Post by herb »
Hello Pierre,
thanks for the info and a Happy New Year!
Best regards
herb
