Import categories issue.
Gwenael Q.
Post by Gwenael Q. »
Happy new year for everybody !
Importing categories with a text file will not give the expected result if categories tree not empty.
Steps to reproduce
- download zip file and extract its content (they are very short text files but I was not able to upload them with txt extension...)
[- Make sure to backup your categories with Categories > local menu > Categories management > export]
- Categories > local menu > Categories management > Clear all
- Categories > local menu > Categories management > import. select "XnviewMP categories import issue 1.txt"
- Categories > local menu > Categories management > import. select "XnviewMP categories import issue 2.txt"
Category tree is not what expected.
Should be:
Document
----Location
--------Italy
--------Namaqualand
Thanks for listening
1.4.0
Re: Import categories issue.
Gwenael Q.
Hello.
Replicated 1.4.2
Thanks for the good work
