B2: 2 txt bugs
Locked
Dreamer
B2: 2 txt bugs
Post by Dreamer »
Steps with my ini only:
- in Options > Browser > Open action > Text files > "Open in xnview"
- restart xnview
- place 1 txt and 2 jpg files to new folder
- double-click the txt file in browser
- txt file is shown
- press page down
- image is shown
- press page up
- another image is shown
- try to switch between all files
= there are just 2 images there, no txt file :bug: #1
- press Escape
- go to txt file
- press Enter
= error dialog is shown :bug: #2
Steps with default settings (strange):
- restart xnview
- double-click the txt file in browser, or press Enter on txt file
- select txt image in browser
- press F11
- txt file is shown in fullscreen correctly
then
- press page down
- image is shown
- press page up
Worse, worse…
:) Hello !
• I prepared the files in an empty dir. in order to test your steps…
- Here, "Use all formats" is checked in "General >> Startup"
- Then, all boxes for the text files are checked in the dialogue "Displayed files"
- In the browser, as soon as I 2-click on the thumb-nail of the text-file, I get the beloved message" Format of <xxx.txt> couldn't be determined". Several tries, same result. BUT : The text file is displayed in the preview area ! :P :bug:
- PageDown doesn't display another file, simply it removes the current file in the preview area, same with PageUp.
- I can display the pics normally via 2-click, though.
- I can switch between the files using <— —> arrow-keys, that works in the preview; in this case, the text does not trigger the error message !
- Escape >> Back to the browser, 1-click on the text thumb-nail : right preview without the error message !
:| No further for that night… I'll test with default settings a bit later. This part might be cleared first, I think…
:mrgreen: KR
With minimal default---
:) Hi !
- With the minimal default settings and "Open in XnView" for the text files, I get exactly the same behaviour than above; the full screen is right, like you say, but the other differences remain.
:mrgreen: K R
Re: B2: 2 txt bugs
Dreamer wrote:Steps with my ini only:
- restart xnview
- txt file is shown
- press page down
- image is shown
- press page up
- press Escape
- go to txt file
- press Enter
- restart xnview
- press F11
then
- press page down
- image is shown
- press page up
Yes, it's an error, open action for text must not exist...
ckv
Post by ckv »
I can't reproduce this in B3 so is this fixed or what?
Dreamer
Post by Dreamer »
"Fixed" / feature removed.
Closed.
Locked
