I've never had problems with XNView MP, until now.
After the update to 1.4.0 I have only a white screen or I can only see one picture in the fullscreen mode.
I can't see any other view. I have no clou what happend, but right now I am not able to use your program.
White Screen with start [Solved]
Re: White Screen with start.
you had no this problem with 1.3.1?? when you start XnView in browser mode no content?
123456789CAREL
Yes no problem before. The program crashed after "viewing" pictures directly from MS onedrive. And since than no way to view the pictures in the "browser mode"
I have unistalled it a couple of times, reinstalled it as many times....
I do not have any clue what might be the problem. After one instalation I was able to view some pictures for a couple minutes but after rebooting, nothing...
If I go with my mouse ofter the icon in the taskbar I can see the browser mode.
Further information to my system: Lenovo ThinkPad P50s, second screen via VGA to HDMI, pictures are most of the time on my external SSD.
please try to rename the xnview.ini?
123456789CAREL
I can't find such a file. There is no "xnview.ini" file within the "XnViewMP" programm folder.
123456789CAREL
I looks like, whenever I open XnViewMP it opens the program with the preview window on the main screen an I can't close this one until I set the "browser mode" to my secondary screen via my taskbar and the GPU settings. It is a workaournd, but sometimes I don't have my second screen, so no way to view pictures in the browser mode.
It's in 'C:\Users\...\AppData\Roaming\XnViewMP'123456789CAREL wrote: Fri Jan 20, 2023 6:18 am I can't find such a file. There is no "xnview.ini" file within the "XnViewMP" programm folder.
123456789CAREL
Thanks Pierre,
changing the name and restarting it was the solution.
