Add Batch remane (cmd_batchRename) to Viewer mode
HanVroon
Post by HanVroon »
Hi Pierre,
I have a request for adding Batch rename to Viewer mode.
In Interface, tab Shortcuts, Browser mode, we can assign a shortcut to Batch convert and Batch rename.
But in Viewer mode only a shortcut to Batch convert is possible.
Could you add Batch remane (cmd_batchRename) to Viewer mode?
I use the rename function a lot with the replace template, and would like to use that rename template in Viewer mode as well instead of F2 and typing the change every time.
Thank you and congratulations with the version 1.00 milestone!
Han
HanVroon
Re: Add Batch remane (cmd_batchRename) to Viewer mode
Post by HanVroon »
Hi Pierre,
Just asking once... is this something you could/would implement, or rather not?
Kind regards,
Han
