format colors broken?
hawaii
Post by hawaii »
I have changed the format colors of particular files pdf, tga, PSD, ai, 3dm, dwg, dgf and only PSD format changed.
Browser > File List > Format Colours
I have closed out of XnViewMP and restarted the application. The issue persists. I have changed to different directories and does not change. I optimized the catalog and no changes.
Additionally, I deleted some formats that I do not use and restarted the application and the default formats came back and doubled the ones I manually added.
Also, this is a brand new install on a machine that has never had XnView installed. The catalog and settings are saved within the application folder.
XnView MP Windows
Version 1.4.0 64bits (Dec 12 2022)
Libformat version 7.132
hawaii
Re: format colors broken?
Post by hawaii »
I changed integration from the application folder to the user system and the issue continues.
could you send me your xnview.ini?
hawaii
Post by hawaii »
what is:
"@ByteArray"
"@Variant"
[Start]
checkFreq=2
language=
style=-3
lastCheck=@Variant(\0\0\0\xe\0%\x89\x36)
geom=@ByteArray(\x1\xd9\xd0\xcb\0\x3\0\0\xff\xff\xff\xff\xff\xff\xff\xf9\0\0\b\0\0\0\x4\x42\0\0\x2W\0\0\0\xeb\0\0\x5\xa8\0\0\x3V\0\0\0\0\x2\0\0\0\b\0\0\0\0\0\0\0\0\x17\0\0\a\xff\0\0\x4\x41)
session=@Invalid()
sessionIdx=-1
RecentFiles=
OpenWith=@Invalid()
OpenWithName=@Invalid()
OpenWithParam=@Invalid()
PathBrowser=
LastFilename=
startupType=1
customPath=
startInFull=0
startBrowser=true
restoreLastFilename=false
singleView=false
oneInstance=true
debug=0
classicSaveDialog=false
scanClose=true
otherFlag=0
otherFolder=
dbFlag=0
dbFolder=
dbThumbFlag=4
dbThumbFolder=
sessionFlag=0
toolbar=default.bar
shortcut=default.keys
toolbarIcons=
lastDBCheck=@Variant(\0\0\0\xe\0%\x89\x37)
[%General]
useAnonymousLogs=false
allFormats=true
version=@ByteArray(1.4.0)
useRecycleBin=true
confirmDel=true
selectNewFiles=true
m_copyTemplate=1
savingKeepDate=false
metaKeepDate=true
savingChanges=0
renameDialog=false
lrotateBackup=false
lcropBackup=true
lotherBackup=true
pasteIntoSubfolder=false
useTabs=true
tabsOnBottom=false
tabWidthMax=20
tabMax=0
tabClose=true
tabThumb=1
tabDoubleClick=1
tabIconify=false
showWriteSettings=false
showMostUsedFormat=true
sync=false
maxRecent=20
purgeRecent=false
dblMode=1
midMode=0
enterMode=1
escKeyMode=0
zoomPan=true
positiveRatio=true
showAgain=0
showAgainResults=@Variant(\0\0\0\b\0\0\0\0)
useInternalVideoPlayer=true
dropLink=false
formats=@Invalid()
[Viewer]
fullBackColor=55 55 55
backColor=55 55 55
adjustZoomDpi=true
ratio=0
fit=1
defaultFit=-1
fullscreenFit=1
defaultFullscreenFit=-1
useAnimation=true
highlightSelection=true
selectionGrid=1
viewFilter=3671
readAhead=true
cacheBehind=true
zoomQuality=1
resizeFilter=0
loop=false
slideDelay=2000
slideDir=0
full2Monitor=false
full2HideTB=true
full2HideSB=true
fullFloatView=true
fullHideMouse=true
infoOnlyFullscreen=true
infoTemplate="{File Index} - {Filename}\n{Format} - {Size KB} KB - {Width}x{Height}\n({EXIF:Date Taken}) ({EXIF:Make}) ({EXIF:Model}) ({Zoom}%)\n({Tag status}) ({Rating}) ({Color label}) "
infoHTMLTags=true
infoBackColor=255 255 255
infoColor=0 0 0
infoOpacity=70
infoFont=@Variant(\0\0\0@\0\0\0\x1c\0M\0S\0 \0S\0h\0\x65\0l\0l\0 \0\x44\0l\0g\0 \0\x32@\x1f\x33\x33\x33\x33\x33\x33\xff\xff\xff\xff\x5\x1\0\x32\x10)
infoPosition=0
titleTemplate={Filename With Ext}
useChecker=false
checkerColor1=255 255 255 255
checkerColor2=240 240 240 255
checkBoardSize=8
useBorderLine=false
borderLineColor=0 0 0
hdpiPixel=false
pasteKeepRatio=false
resetXY=false
resetFit=true
scrollbarValue=20
autoPlay=false
loopVideo=false
playVideo=true
hideScrollbar=true
useGamma=false
gamma=1.2
useSharpen=false
sharpen=50
useZoom=false
zoomFixed=10
zoomRelative=1.41421356
prevSize=@Size(160 120)
iconSnapshot=false
defaultFormat=@ByteArray(jpeg)
saveFolder=
saveUseOrg=false
saveasUseFormat=false
saveCopy=false
useNewName=true
multipleView=false
maxViewTab=99
lastTab=true
lKeyLR=1
lKeyUD=0
spaceKey=0
lButtonAction=1
lButtonCtrlAction=0
mButtonAction=2
rButtonAction=0
rButtonCtrlAction=-1
wheelAction=0
wheelCtrlAction=2
statusBar=true
toolBar=true
showRegion=false
printSizeUnit=0
clearColor=0 0 0
savedSelection=@Rect(0 0 0 0)
usePan=true
histoState=@ByteArray(\0\0\0\x1\0\0\0\0\x1\0\0\0\x80\x1\x1\xff\xff\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0)
panSize=@Size(90 90)
useInfo=true
usePlaybar=true
lockZoom=false
lockZoomFlag=true
videoPlaybar=true
audioVolume=100
useAlpha=true
showRating=true
state=@ByteArray(\0\0\0\xff\0\0\0\0\xfd\0\0\0\0\0\0\b\0\0\0\x3\xb9\0\0\0\x4\0\0\0\x4\0\0\0\b\0\0\0\b\xfc\0\0\0\x1\0\0\0\x2\0\0\0\x1\0\0\0\x12\0T\0o\0o\0l\0\x42\0\x61\0r\0 \0\x31\x1\0\0\0\0\xff\xff\xff\xff\0\0\0\0\0\0\0\0)
showHisto=false
showInfo=false
showGrid=false
[Browser]
prevBackColor=55 55 55
size=@Size(2048 1035)
state=@ByteArray(\0\0\0\xff\0\0\0\0\xfd\0\0\0\x2\0\0\0\0\0\0\x1^\0\0\x3\xbb\xfc\x2\0\0\0\x3\xfb\0\0\0\xe\0\x66\0i\0l\0t\0\x65\0r\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0\0\0\0\0\0\xfc\0\0\0<\0\0\x2[\0\0\0y\0\xff\xff\xff\xfa\0\0\0\0\x2\0\0\0\x3\xfb\0\0\0\xe\0\x66\0o\0l\0\x64\0\x65\0r\0\x44\x1\0\0\0\0\xff\xff\xff\xff\0\0\0Y\0\xff\xff\xff\xfb\0\0\0\x12\0\x66\0\x61\0v\0o\0r\0i\0t\0\x65\0\x44\x1\0\0\0\0\xff\xff\xff\xff\0\0\0Y\0\xff\xff\xff\xfb\0\0\0\x12\0\x63\0\x61\0t\0\x65\0g\0o\0r\0y\0\x44\x1\0\0\0\0\xff\xff\xff\xff\0\0\0\x13\0\xff\xff\xff\xfc\0\0\x2\x9d\0\0\x1Z\0\0\0y\0\xff\xff\xff\xfa\0\0\0\x1\x1\0\0\0\x2\xfb\0\0\0\x16\0P\0r\0\x65\0v\0i\0\x65\0w\0\x44\0o\0\x63\0k\x1\0\0\0\0\0\0\x1\x19\0\0\0\x46\0\xff\xff\xff\xfb\0\0\0\n\0p\0r\0\x65\0v\0\x44\x1\0\0\0\0\xff\xff\xff\xff\0\0\0\x7f\0\xff\xff\xff\0\0\0\x3\0\0\b\0\0\0\x1@\xfc\x1\0\0\0\x1\xfc\0\0\x5k\0\0\x2\x95\0\0\0\0\0\xff\xff\xff\xfa\xff\xff\xff\xff\x2\0\0\0\x2\xfb\0\0\0\b\0\x63\0\x61\0t\0\x44\0\0\0\0\0\xff\xff\xff\xff\0\0\0u\0\xff\xff\xff\xfb\0\0\0\n\0s\0\x65\0t\0s\0\x44\0\0\0\x1\x38\0\0\x1\t\0\0\0\x91\0\xff\xff\xff\0\0\x6\x9c\0\0\x3\xbb\0\0\0\x4\0\0\0\x4\0\0\0\b\0\0\0\b\xfc\0\0\0\x1\0\0\0\x2\0\0\0\x1\0\0\0\x12\0T\0o\0o\0l\0\x42\0\x61\0r\0 \0\x31\x1\0\0\0\0\xff\xff\xff\xff\0\0\0\0\0\0\0\0)
thumbSize=@Size(128 96)
useThumbSize=true
thumbsPerColumn=4
Tab=4294967291
header="@ByteArray(\0\0\0\xff\0\0\0\0\0\0\0\x1\0\0\0\0\0\0\0\0\x1\0\0\0-\0\0\0\x1\0\0\0\0\0\0\0\x2\0\0\0\x3\0\0\0\x4\0\0\0\x5\0\0\0\x6\0\0\0\a\0\0\0\b\0\0\0\t\0\0\0\n\0\0\0\v\0\0\0\f\0\0\0\r\0\0\0\xe\0\0\0\xf\0\0\0\x10\0\0\0\x11\0\0\0\x12\0\0\0\x13\0\0\0\x14\0\0\0\x15\0\0\0\x16\0\0\0\x17\0\0\0\x18\0\0\0\x19\0\0\0\x1a\0\0\0\x1b\0\0\0\x1c\0\0\0\x1d\0\0\0\x1e\0\0\0\x1f\0\0\0 \0\0\0!\0\0\0\"\0\0\0#\0\0\0$\0\0\0%\0\0\0&\0\0\0'\0\0\0(\0\0\0)\0\0\0*\0\0\0+\0\0\0,\0\0\0-\0\0\0\x1\0\0\0\0\0\0\0\x2\0\0\0\x3\0\0\0\x4\0\0\0\x5\0\0\0\x6\0\0\0\a\0\0\0\b\0\0\0\t\0\0\0\n\0\0\0\v\0\0\0\f\0\0\0\r\0\0\0\xe\0\0\0\xf\0\0\0\x10\0\0\0\x11\0\0\0\x12\0\0\0\x13\0\0\0\x14\0\0\0\x15\0\0\0\x16\0\0\0\x17\0\0\0\x18\0\0\0\x19\0\0\0\x1a\0\0\0\x1b\0\0\0\x1c\0\0\0\x1d\0\0\0\x1e\0\0\0\x1f\0\0\0 \0\0\0!\0\0\0\"\0\0\0#\0\0\0$\0\0\0%\0\0\0&\0\0\0'\0\0\0(\0\0\0)\0\0\0*\0\0\0+\0\0\0,\0\0\0\0\0\0\0\0\0\0\x11\x94\0\0\0-\x1\x1\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\x64\xff\xff\xff\xff\0\0\0\x81\0\0\0\0\0\0\0-\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\x3\xe8\0\0\0\0\x64)"
header2=false
viewAs=1
sort=0
sortOrder=0
sortNameMethod=0
mixFileFolder=false
folderAlphabeticalSorting=false
recognizeByExt=true
showHiddenFiles=false
showCompanionFiles=true
filter=4
customFilter=3831
thumbnailFilter=3793
custom1Ext=htm, html, mht, mhtml, xml, xhtml, eml, nws, url, svg, svgz
custom2Ext=
sizeInBytes=false
commentField=0
tooltips=<b>{Filename}</b><br>{Modified Date} - {EXIF:Date taken}<br>{Size KB} Kib
useTooltips=true
titleBarTemplate=
layout=-1
onTheFly=false
customThumbSize=@Size(96 96)
tagReset=3
selectOnEnterFolder=false
newFilesAtBottom=true
rotationKeepDate=true
rotationChangeExif=false
rotationUseLossless=true
openAction_0=2
openAction_1=2
openAction_2=2
openAction_3=1
openAction_4=2
openAction_5=1
openAction_6=1
toolBar=true
statusBar=true
smallToolBar=true
showPaneTitle=true
vTabs=true
statusBarFlags=31
statusBarDate=1
toolbarFlags=127
use4VideoThumb=true
use4Thumb=true
ratingLabel=@Invalid()
folderColor1=255 255 170
folderColor2=255 200 74
folderColor3=197 140 0
folderColor4=250 210 105
folderColor5=172 140 53
useRating=true
scrollPerThumb=true
keyDelayedPrev=false
catMatchAll=false
catMode=0
searchFlags=14
categoryStatus="1,1,0,1,0,0"
littleBarVersion=0
scanHeaders=0
favShowFiles=false
audioVolume=100
templateXMP=false
[Appearance]
defaultLabelColor=225 225 225
defaultLabelBColor=38 38 38
useShadow=false
thumbBackColor=38 38 38
thumbBorderColor=38 38 38
borderColor=38 38 38
useLabelSpacing=true
labelAlign=1
labelFont=@Variant(\0\0\0@\0\0\0\x1c\0M\0S\0 \0S\0h\0\x65\0l\0l\0 \0\x44\0l\0g\0 \0\x32@\x1f\x33\x33\x33\x33\x33\x33\xff\xff\xff\xff\x5\x1\0\x32\x10)
overlayIcons=65535
itemSpacing=0
borderSize=1
useThumbBackColor=true
thumbBorderSize=3
thumbPadding=10
customLabel-1={EXIF:Focal Length}mm f/{EXIF:F-Number} {EXIF:Exposure Time}s {EXIF:ISO Value}iso
customLabel-2={Width}x{Height} - {Size KB}
customLabel-3=
customLabel-4=
customLabel-5=
thumbLabels="1 55 2 39 54 "
formatColor-0="[jpeg],237 237 202,0 0 0"
formatColor-1="[png],232 222 220,0 0 0"
formatColor-2="[bmp],227 227 255,0 0 0"
formatColor-3="[tiff],192 197 235,0 0 0"
formatColor-4="[iff],247 235 235,0 0 0"
formatColor-5="[sgi],247 237 242,0 0 0"
formatColor-6="[psd],0 85 255,0 0 0"
formatColor-7="[emf],212 212 212,0 0 0"
formatColor-8="[pdf],255 0 0,0 0 0"
formatColor-9="[3dm],85 170 127,0 0 0"
formatColor-10="[dwf],85 255 255,0 0 0"
formatColor-11="[ai],248 139 51,225 225 225"
formatColor-12="[rvt],0 170 127,225 225 225"
formatColor-13="[pbm],191 191 182,0 0 0"
formatColor-14="[pgm],207 207 197,0 0 0"
formatColor-15="[ppm],235 225 159,0 0 0"
formatColor-16="[ras],255 255 227,0 0 0"
formatColor-17="[wmf],187 187 187,0 0 0"
formatColor-18="[emf],212 212 212,0 0 0"
formatColor-19="[ico],217 247 227,0 0 0"
formatColor-20="[cur],217 247 227,0 0 0"
formatColor-21="[ani],217 247 227,0 0 0"
formatColor-22="[fpx],229 255 255,0 0 0"
formatColor-23="[pdf],255 0 0,0 0 0"
formatColor-24="[3dm],85 170 127,0 0 0"
formatColor-25="[dwg],85 255 255,0 0 0"
useFormatColor=true
selectedColor=10 36 106
formatColor-26="[ai],248 139 51,225 225 225"
formatColor-27="[rvt],0 170 127,225 225 225"
formatColor-28="[tga],85 85 255,225 225 225"
formatColor-29="[3dmbak],60 120 89,255 255 255"
[Settings]
geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x3\0\0\0\0\x1\xc1\0\0\0\x90\0\0\x5\x37\0\0\x3+\0\0\x1\xc2\0\0\0\xae\0\0\x5\x36\0\0\x3*\0\0\0\0\0\0\0\0\b\0\0\0\x1\xc2\0\0\0\xae\0\0\x5\x36\0\0\x3*)
cacheList=@ByteArray(\0\0\0\xff\0\0\0\0\0\0\0\x1\0\0\0\0\0\0\0\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\x2\x65\0\0\0\x3\x1\x1\0\x1\0\0\0\0\0\0\0\0\0\0\0\0\x64\xff\xff\xff\xff\0\0\0\x81\0\0\0\0\0\0\0\x3\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\0\x64\0\0\0\x1\0\0\0\0\0\0\x1\x9d\0\0\0\x1\0\0\0\0\0\0\x3\xe8\0\0\0\0\x64)
[Preview]
info=@ByteArray(\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1\x1)
showAlwaysTabs=false
tabs=true
vTab=65406
prevDocked=true
fit=1
[CatSets]
history=@ByteArray(\0\0\0\x1\0\0\0\0)
panel=@ByteArray(\0\0\0\x1\0\0\0\x3\xff\xff\xff\xff\x1\xff\xff\xff\xfe\x1\xff\xff\xff\xfd\x1)
[Load]
useEmbeddedThumb=true
useOrgIfSmaller=false
useHighQuality=true
useSharpen=false
sharpen=50
useGamma=false
gamma=1
noReadError=false
useEXIFRotation=true
useEXIFDpi=true
composeWithTrans=false
composeWithAlpha=false
useICCProfile=false
ICCIntent=1
ICCProfile=
useSystemICC=false
ICCRGBDefault=0
ICCRGBDefaultProfile=
ICCCMYKDefault=1
ICCCMYKDefaultProfile=
RAWFlag=0
RAWAutoBalance=true
RAWCameraBalance=false
RAWAutoBrightness=true
RAWColorMatrix=true
RAWBrightness=@Variant(\0\0\0\x87?\x80\0\0)
RAWRedScaling=@Variant(\0\0\0\x87?\x80\0\0)
RAWBlueScaling=@Variant(\0\0\0\x87?\x80\0\0)
RAWsRGB=true
RAWUseLibRaw=true
PCDBase=2
GrobBpp=0
DjVuMaxDpi=false
WMFHighRes=false
PDFDpi=72
PDFPageSize=0
PDFCIE=false
ICOIn32bits=false
PDDPage=0
EXRGamma=@Variant(\0\0\0\x87@\f\xcc\xcd)
HDRGamma=@Variant(\0\0\0\x87@\f\xcc\xcd)
DPXInRGB=true
PSDFixAlpha=false
FITSMode=0
YUVWidth=720
YUVHeight=576
YUVOffset=0
RAWBpp=24
RAWWidth=256
RAWHeight=256
RAWOffset=0
channelOrder=0
channelType=0
byteOrder=0
videoFrameP=0
useAlpha=true
[Save]
addExtensionIfNeeded=true
keepOriginalDate=true
keepEXIF=true
keepIPTC=true
keepXMP=true
keepICC=true
JPEGQuality=80
JPEGProgressive=false
JPEGOptimizeHuffmanTable=false
JPEGRebuildThumb=true
useOriginalJPEGQuality=false
JPEGDCTMethod=0
JPEGSubSampling=0
JPEGSmoothFactor=0
WebPQuality=80
WebPFileSize=128
WebPMethod=0
WebPCompress=4
WebPStrength=60
WebPSharpness=0
WebPPreset=0
AvifCodec=0
AvifFormat=0
AvifSpeed=5
AvifColorLossless=true
AvifColorMin=0
AvifColorMax=63
AvifAlphaLossless=true
AvifAlphaMin=0
AvifAlphaMax=63
JpegXRQuality=80
JpegXRColorFormat=0
JpegXRFilter=0
JpegXLQuality=80
JpegXLLossless=true
JpegXLEffort=7
HeicQuality=80
PNGCompressionLevel=6
PNGInterlaced=false
PNGFilter=0
GIFInterlaced=false
GIF87aHeader=false
IFFCompress=false
PCXCompress=false
TGACompress=false
TGABottomUp=false
SOFTCompress=true
SGICompress=true
BMPCompress=false
OS2Header=false
HP49Header=false
PPMInAscii=false
TIFFCompress=0
TIFFQuality=80
TIFFBinaryCompress=0
TIFFOnlyOneStrip=false
DPXMsbf=false
DPXInRGB=true
PDFBinaryCompress=0
PDFGreyscaleCompress=0
PDFColorCompress=0
PDFJpegQuality=80
JP2KMode=0
JP2KQuality=80
JP2KRatio=4
JP2KFileSize=100
RAWOffset=0
channelOrder=0
channelType=0
[Companion]
useForDelete=false
useForOther=false
list="@Variant(\0\0\0\v\0\0\0\x2\0\0\0\x2\0*\0\0\0\x1a\0{\0\x65\0x\0t\0}\0.\0x\0m\0p\0;\0x\0m\0p)", @Variant(\0\0\0\v\0\0\0\x2\0\0\0\n\0{\0r\0\x61\0w\0}\0\0\0\x6\0j\0p\0g), "@Variant(\0\0\0\v\0\0\0\x2\0\0\0\n\0{\0r\0\x61\0w\0}\0\0\0 \0l\0m\0n\0r\0;\0p\0p\0\x33\0;\0o\0n\0\x31\0;\0\x66\0p\0\x31)", @Variant(\0\0\0\v\0\0\0\x2\0\0\0\x6\0j\0p\0g\0\0\0\x6\0\x65\0x\0\x66)
[DB]
useCatalog=true
thumbInDB=true
folder=@Invalid()
cacheComp=1
excludeRemovable=true
excludeCD=true
basePath=/
useMaxCache=false
maxCache=100
thumbWidth=192
thumbHeight=144
dbCacheSize=50
dbCheck=1
folderFlag=@Invalid()
[Keywords]
import=true
updateFileChanged=false
export=false
exportFlags=1
applyParent=false
readHierarchical=true
writeHierarchical=false
characters=0
updateSidecar=false
sidecarJPEG=true
sidecarPNG=true
sidecarRAW=true
sidecarOther=true
useFilenameXmp=true
importFace=false
[XMP]
xmpRating=false
xmpLabel=false
xmpComment=false
[IPTC]
defaultCodec=0
utf8Save=true
[Metadata]
commentCodec=0
useUtf8ForDescription=false
exifCodec=26
[ColorLabel]
label_0=Uncolored
label_1=
read_1=Red, Select
write_1=Red
label_2=
read_2=Yellow, Second
write_2=Yellow
label_3=
read_3=Green, Approved
write_3=Green
label_4=
read_4=Blue, Review
write_4=Blue
label_5=
read_5=Purple, To Do
write_5=Purple
[Format]
ps=pdf ps epsf eps ai
text=cc pas txt ini cpp c js c++ h php css gcode xmp
avi=vob wmv divx asf avi vfw
qt=3gp 3gp2 mov 3g2 qt
mpeg=m1s mpa mpg mpe mp4 mpm m2ts m1v m4v mpeg m4a m2v mts
video=flv mkv ts rm aae mxf webm
audio=snd ogg rmi mpp asx mp2 au mpc mid wav wma flac mp3 aif mp+
archive=zip gz cbz 7z tar arj cbr rar tgz
[DBClean]
geometry=@ByteArray(\x1\xd9\xd0\xcb\0\x3\0\0\0\0\x2\xb3\0\0\x1\x62\0\0\x4\x44\0\0\x2Y\0\0\x2\xb4\0\0\x1\x80\0\0\x4\x43\0\0\x2X\0\0\0\0\0\0\0\0\b\0\0\0\x2\xb4\0\0\x1\x80\0\0\x4\x43\0\0\x2X)
optimize=true
emptyFolder=true
thumb=true
files=true
orphanedFolder=false
orphanedFile=false
there is 2 pdf lines
I've tried in a folder with pdf, and labels are red, you have not that?
hawaii
Post by hawaii »
Yes, PSD, PDF, show colors. I added tga and it shows colors, but not others mentioned. The format colors I added doubled when I deleted the default lines when I restarted the application.
hawaii wrote: Sun Jan 15, 2023 8:50 am Yes, PSD, PDF, show colors. I added tga and it shows colors, but not others mentioned. The format colors I added doubled when I deleted the default lines when I restarted the application.
which one are not used?
hawaii
Post by hawaii »
i removed pbm, pgm, ppm, ras, wmf, emf, ico, cur, ani, fpx and after i restart the application they readded by themselves. as shown in the first post image under the extension rvt and the ones i added doubled on their own below them shown in the first post image.
now, i deleted the extensions that I added and showing on the top in the first post image, and restarted the application and now they readded themselves and display below the bottom ones that previously added themselves. image below. however, deleting the pdf one on the top remained deleted and did not readd itself. also the top 3dm extension deleted itself and did not readd. this is strange.
hawaii
Post by hawaii »
3dm, dwg, ai, rvt, 3dmbak are not showing colors.
there is some error, for example: you must enter 3dm as extension and not [3dm]
formatColor-9="3dm,85 170 127,0 0 0"
formatColor-10="dwf,85 255 255,0 0 0"
formatColor-11="ai,248 139 51,225 225 225"
formatColor-12="rvt,0 170 127,225 225 225"
hawaii
Post by hawaii »
interesting. pdf, psd, and tga allowed me to do it that way.
hawaii wrote: Sun Jan 15, 2023 4:45 pm interesting. pdf, psd, and tga allowed me to do it that way.
yes, these name are used as format name not extension
