there is a bug with double clicking mouse.
I was testing with v1.3.1 and 1.4.0 on Windows 11.
It happens if you doubleclick (left mouse button) a folder in browserview (right main window).
you can easy reproduce this if you doubleclick a folder and not releasing the second click. the next page will count this as a singleclick/holding left mouse button. xnviewmp is then in marking files/folder state.
this also happen if you just do a normal doubleclick because sometimes xnviewmp is still counting a singleclick on the next page.
it should be so thats xnviewmp is executing the doubleclick after releasing the second click.
i hope my report is understandable and can be used to fix this bug
Doubleclick Problem
Re: Doubleclick Problem
right, folder must be changed after release of second click
Dudeldei
The Bug is still there on the current version.
Can you please fix this? just want to know if you forget about it or just dont want to fix it?
thanks
yes, but not easy to fix...
