b2: [bug] information label not updated after rename
Locked
FlorianH
Post by FlorianH »
After renaming a file in viewer or fullscreen (with 'show information' activated), the information label (file name) is not updated (same in v1.80.x).
Switching 'show information' off and on again helps...
Yes, but trivial
:) Hi !
- Confirmed, the "OK" button of the "Rename" dialogue is not sufficient…
- A trivial issue, since like you say playing with the "I" key makes the display is refreshed.
- I guess that an “Apply” button is missing on several dialogues to avoid such minor inconveniences…
:mrgreen: VG
Dreamer
Re: Yes, but trivial
Post by Dreamer »
Confirmed, in viewer and FS, not in FS 'lite'.
Clo wrote:- I guess that an “Apply” button is missing on several dialogues to avoid such minor inconveniences…
OK button must apply change first and then close dialog, I think no Apply button is needed here.
Or---
:arrow: Dreamer
:) Hi !
- Obviously, this <OK> button doesn't…
- Either this is not possible in all cases, or it's a minor :bug:
:mrgreen: KR
Dreamer
Re: Or---
Post by Dreamer »
Clo wrote:- Obviously, this <OK> button doesn't…
Of course, I said it's a bug, maybe just misunderstanding - I just think there should be just one button OK, not two - OK and Apply.
Dreamer
Post by Dreamer »
Fixed.
Closed.
Locked
