I often try to get the latest libraries for different picture formats.
Maybe it is possible to refresh the currently used dlls with the newest.
There is a autobuild media suite at github available, which build the required picture format dlls for XnviewMP.
https://github.com/m-ab-s/media-autobuild_suite
Maybe it is a good tool for Pierre to compile the required dlls.
JPEG XL 0.82:
Changelog: https://github.com/libjxl/libjxl/releases/tag/v0.8.2
Download: https://github.com/libjxl/libjxl/releases/tag/v0.8.2
WebP 1.3 library is available:
https://storage.googleapis.com/download ... index.html
Google do not offer a libwebp.dll in their download package.
There is another free image tool 'ImageMagick', which contain the same webp dlls.
Download: https://imagemagick.org/script/download.php#windows
The dll works well with XnviewMP.
LIBHEIF 1.14.2
The StrukturAG offer the latest libheif library for reading and writing files.
https://github.com/strukturag/libheif/r ... ag/v1.14.2
There is no dll for direct download available.
But the latest ImageMagick contain the dll which is compatible with XnviewMP.
Currently it is version 1.22, but maybe the next release use a newer one.
Refresh of XnviewMP librarys: Jpeg XL 0.82, WEBP 1.3, LIBHEIF 1.14.2
masterjp
Re: Refresh of XnviewMP librarys: Jpeg XL 0.80, WEBP 1.3, LIBHEIF 1.14.2
I use vcpkg for third party dll,
Not yet available...
Will not update for next version, there is some big changesWebP 1.3 library is available:[/b]
will be updatedLIBHEIF 1.14.2
masterjp
Thank you for the update.
The new libarys of XnviewMP 1.4.2 solved some stupid bugs in saved AVIF/HEIC files.
In the past I saw black lines in my avif/heif/heic pictures, if the width or height has an odd size.
Now the problem is fixed.
dedbombom
Actually libjxl devs already building v0.8.x using vcpkg https://github.com/libjxl/libjxl/action ... 4063357408
dedbombom
Also would be nice if ancient (?) AVIFlib.dll updated from https://aomedia.googlesource.com/aom/+/refs/tags/v3.1.1 (?) up to https://aomedia.googlesource.com/aom/+/refs/tags/v3.6.1 if possible,
Kadet
Kadet
