Missing feature: Hide tab bar
Stock
Post by Stock »
MP is missing a really cool feature.
In Classic you could automagically hide the tab bar if there is only one open window:
3 tab classic.png (25.14 KiB) Viewed 10594 times
This is awesome if you quickly want to view a single picture as you don't need tabs and the pic gets maximum vertical viewing space.
The smart tab bar setting is sorely missing in XnView MP.
Re: Missing feature: Hide tab bar
ok, i'll try to add it
Stock
Post by Stock »
Just installed 1.5.0 final.
'Hide tab when only 1 opened' is working splendidly.
When I have only one picture, I get maximum space.
Once I open another picture, the tab bar is shown.
If I close the second picture, the tab bar disappears as expected.
It's time to fully switch to MP.
user0 wrote: Fri Jul 07, 2023 7:18 pm 1.5.0 final
issues
0. check new "Hide Tb when only one is openned" checkbox
Please make a separate post
jonha4711
Post by jonha4711 »
As I have suggested in another thread I would very much like to see an option to disable displaying the tab bar altogether but leaving the keyboard shortcuts for tab-switching in place ( see viewtopic.php?f=60&t=44675&p=184086#p184086 ).
adrido
Post by adrido »
I am having an issue with this feature.
It only works as it is supposed the first time. After I check the "Hide Tb when only one is opened" checkbox and confirm with "OK" the tab is hidden and the picture goes full-screen.
However, if I close XnView and open a new file, the tab will be visible. In the settings the checkbox is still checked.
