Batch function to report metadata of images in a folder?
Willebra
is a batch function available to create a report with metadaten from all pictures in a folder??
Re: Batch function to report metadata of images in a folder?
Select some files or folders in the browser.
Then, you can use Create > File listing
Add the fields you need with the arrow at the end of the box.
Text, separators can also be added ...
Various options are offered in this window
If you only want to view metadata, you can use : View > View as ... > Details
... and right click in headers to add, remove or move columns
Catalogage avec XnviewMP :
BuckSkin
Good question and thank you for asking it !Willebra wrote: Thu Jan 19, 2023 10:19 am is a batch function available to create a report with metadaten from all pictures in a folder??
Thank you so much for this; I had no idea these features had these functions and abilities.michel038 wrote: Thu Jan 19, 2023 3:13 pm Select some files or folders in the browser.
I am hoping there is a way to save a recipe once it is created as it is a slow go to create the recipe.
