I can't get color management to work under macOS
UrbanCoyote
Post by UrbanCoyote »
I simply can't get color management to work under macOS.
I'm running a wide gammut benq.
It's been calibrated via palette master.
Preview, finder, Affinity photo, lightroom and capture one all display the image the same - only XNViewMP displays it overstatured.
(much like when I was on windows, un color managed apps displayed my images oversaturated).
The problem is, that even though ICC is turned on in XNViewMP, none of the options have any effect on the outcome.
Is this a known bug? If not, I can submit a bug.
I'm running Ventura 13.1 on an M1 and using XNViewMP 1.4.1 univeral build (although this has happened with previous builds too)
Re: I can't get color management to work under macOS
Do you have enter the monitor profil in ICC Settings?
UrbanCoyote
Yes, the ICC profile is generated by BenQ's Pallete Master and this is selected in XnViewMP.
It is v4 ICC though?
UrbanCoyote wrote: Sun Jan 29, 2023 1:44 am Yes, the ICC profile is generated by BenQ's Pallete Master and this is selected in XnViewMP.
Please send me it?
UrbanCoyote
Sure, hope this works :)
UrbanCoyote
Is it just something funky with my setup or is there an issue perhaps with macOS?
UrbanCoyote wrote: Thu Jun 22, 2023 5:48 am Is it just something funky with my setup or is there an issue perhaps with macOS?
you can try 1.5.0 beta
UrbanCoyote
Thanks!
To report the issue, it still remains in the beta for me. The images are oversattured on widegamut under macos.
Unfortunately the ICC on or off has no effect.
UrbanCoyote
Actually, another update.
Beta 4 fixes the problem (when viewing the image).
However the thumbnails and thumbnail cache remains oversatured on macos. :)
