Way to make Curves open with a saved Preset already loaded?
klj
Post by klj »
How do I save a Curves Preset Default?
I can save presets. But I would like to save a Default that is selected in the curve editor window. There is a menu selection <Default>. How do I use it?
Mac OS 12.1
XnView 1.4.1
Thanks
Re: Curves Default
klj wrote: Fri Jan 20, 2023 4:05 pm How do I save a Curves Preset Default?
The small blue floppy disk icon just to the right of the Presets selection dropdown? :D
klj
Re: Curves Default
Post by klj »
Yes, the disk icon lets me save a setting. But how do I make the setting the Default?
Thanks
Re: Curves Default
klj wrote: Fri Jan 20, 2023 4:40 pm Yes, the disk icon lets me save a setting. But how do I make the setting the Default?
I see the problem: possibly 'Default' is the straight line setting with which the window opens, which can't be changed, and there is currently no way to make Curves open with a saved personal option already loaded??
Pierre?
Re: Way to make Curves open with a saved Preset already loaded?
Simply making the currently set Profile persistent would provide a solution, wouldn't it?
klj
Post by klj »
The "persistent" profile would work great!
Peter2
Post by Peter2 »
1.5 years later - this seem to be not integrated now, right? Or did I miss it?
