renaming multiple images
MartinP
Post by MartinP »
Hi all,
it seems, i've lost the possibility to rename multiple files at once - renaming single files works.
This is the prcess on Windows 10 with version 1.4.1:
mark several files; pres <F2>; menu pops up (sorry german interface); filling in new name and a numbering
after hitting "OK" this appears
saying "Error renamimg. The file could not be renamed"
Well, I'm not using this every day, but I swear it worked last year (round about summer) and now after updating it does not work anymore - in between I can't say. I normally update to every new version, but haven't used multiple renaming in between.
Well there were WIN10 updates in between but my working path where I work with the images before storing them is still the same. And multi renaming with other tools with the same files in the same dir does work normal.
Did I miss a new configuration for that?
Thanks
Martin
Franky
Re: renaming multiple images
Post by Franky »
hi,
I just tested and it works for me.
Is your folder protecting in write ?
You can try with batch convert tool.
You can try an reinstall.
MartinP
Re: renaming multiple images (solved)
Post by MartinP »
Thanks al ot for looking in!
No, it is not an issue with rights or protection or what ever - I found it, it was an issue with the INI file
some years ago I've configured some sidecar definitions for JPG, TIF and other:
if I delete those last lines, renaming is working again
This configuration was cool for having XN to move those files together with the JPG, TIF etc. Well, I dont need this anymore, so I can delete them. But these lines did not influence the renaming until the version in most propbly the December version of last year.
Franky
Post by Franky »
In december, there has been a changement in the rename to respect the case of the companion files, perhaps the origin of the problem ?
here is the change.
MartinP
Post by MartinP »
Franky wrote: Tue Jan 24, 2023 5:12 pm In december, there has been a changement in the rename to respect the case of the companion files, perhaps the origin of the problem ?
here is the change.
yes, it looks like this was the change causing it - thanks
