Plz update broken links
jmara
Post by jmara »
I can´t download new XnView MP for 32bit Windows (both setup and ZIP files), I got error message "Forbidden You don't have permission to access this resource." Please fix it.
Re: Plz update broken links
jmara wrote: Thu Jan 26, 2023 8:03 pm I can´t download new XnView MP for 32bit Windows (both setup and ZIP files), I got error message "Forbidden You don't have permission to access this resource." Please fix it.
Which link did you click on, could you post it?
New 32-bit versions are no longer produced, previous versions can be download if required from this link.
jmara
Post by jmara »
The link on the download page. The header on the download page still says 1.4.1 and there are buttons to download 32-bit versions (both setup and ZIP). The comparation section on the same page says: "Windows, MacOS and Linux are now supported in both 32 and 64 bit versions". Moreover, in 1.4.1+1.4.2 changelog is no sign about 32-bit support dropping. Version 1.4.1 has 32-bit support and there is no reason to drop support in such minor version as 1.4.2 is...
fixed
