B2: WMVs are played with green color effect
Locked
Dreamer
Post by Dreamer »
A known 'bug' (I didn't find original topic), but some new information. WMVs are played with green color effect in xnview. It is the same in all players, but when I change option DirectShow video from 'system default' to 'old renderer' in Windows Media Player Classic, it works good there. So it should be possible to 'fix' it in xnview too.
Re: B2: WMVs are played with green color effect
Dreamer wrote:A known 'bug' (I didn't find original topic), but some new information. WMVs are played with green color effect in xnview. It is the same in all players, but when I change option DirectShow video from 'system default' to 'old renderer' in Windows Media Player Classic, it works good there. So it should be possible to 'fix' it in xnview too.
Windows media player has his own codec, so i have no info for that
ckit
Post by ckit »
Dreamer, using "Media Info 0.7.4" can you find out if these files are WMV1, WMV2 or WMV3?
WMV1 = Windows Media 7 encoded
WMV2 = Windows Media 8 encoded
WMV3 = Windows Media 9 encoded
I'll run my own tests now for this bug.
Usually the "green effect" with video players indicates a video driver problem.
Update:
I can't reproduce this bug, WMP 9, WM_VCM 9, DirectX 9.0c Dec 2005 and ATI 5.12 drivers installed.
Xyzzy
Post by Xyzzy »
I'd opt for Closing this.
I don't think there's hope for another video renderer in XnView.
X.
ckit
Post by ckit »
No, this problem has nothing to do with the video renderer in XnView.
It's something else and I'd like to see how it's turns out as I have an interest in digital video.
Xyzzy
Post by Xyzzy »
Whatever the reason is, it seems not to be a part of XnView.
X.
Dreamer
Post by Dreamer »
But - can anyone confirm 'green effect' too?
I'll try to check my files, ckit, do you have a link to "Media Info 0.7.4", I can't find it.
ckit
Post by ckit »
Yup sure thing, it's a SourceForge project:
http://sourceforge.net/project/showfile ... p_id=86862
ckit
Post by ckit »
Check this site as well.
WMP Mini-FAQ:
http://www.nwlink.com/~zachd/pss/pss.html
Check your codecs against mine:
My Tests:
WMV1 with WMA2's = no green effect
WMV2 with WMA2's = no green effect
WMV3 with WMA2's = no green effect
WMV3 with WMA3's = no green effect
Xyzzy
Post by Xyzzy »
Dreamer, could you post a screenshot and a test video on some file sharing service?
X.
Dreamer
Post by Dreamer »
ckit wrote:Yup sure thing, it's a SourceForge project:
It's MediaInfo, not Media Info, that's the problem.
BTW - thumbnails are OK
Versions of my WMVs:
- video WMV2, audio WMV2 - correct
- video S-Mpeg4 v3, audio WMV2 - correct
- video WMV3, audio WMV2 - green effect
- video WMV3, audio WMV3 - green effect
Screenshot with correct thumbnail and 'green' video in preview:
And - I said it's not exactly xnview's problem, it's the same in other players, but...
...when I change option DirectShow video from 'system default' to 'old renderer' in Windows Media Player Classic, it works good there. So it should be possible to 'fix' it in xnview too.
...and also thumbnails are correct.
ckit
Post by ckit »
I don't know what to suggest, make sure you have the following installed.
DirectX SDK 9.0c Dec 2005
WMP 9.00.00.3263 (you can only get this with WMP patches -> http://www.mdgx.com/wmp.htm)
WMP_VCM 9 codec
Windows Media 10 Codecs for WMP 9
Can you get WMV3 clips to play OK in MPC using VMR9 renderless because you can't your problem lies with DirectX or video card?
Check for any problems in "dxdiag" utility.
Last Resort:
From Desktop -> Properties -> Display Properties -> Settings -> Advanced -> Troubleshooting -> Reduce your Hardware Acceleration by 1 each time and see if that helps.
Xyzzy
Post by Xyzzy »
I see that it is a matter of codecs, so upgrade your codecs or Suggest multiple video rendering engines.
X.
Locked
