Slideshows ignoring Windows display scaling
gordol
Post by gordol »
v1.4.2 in Windows 11. This worked properly in 1.4.0, didn't use this function in the short amount of time 1.4.1 was installed.
Slideshows are now showing images in such a way as to ignore the Display Scale set in Windows.
I have my laptop set to native resolution of 1920x1080 at 125% scaling, and all slideshow images are oversized for the display, with scroll bars that are basically useless in a slideshow. If I reset my display scaling to 100%, this does not happen. Slideshows are set to Fullscreen.
Testing, if I change the slideshow setting to a fixed window size and set it window size, I no longer get the scrollbars, but now it appears that the images are still in full-size overrunning the right and bottom edges of the window.
I have not tried this on my Win11 nor Win10 desktops, though both of those are set to 100% scaling.
konceal
Re: Slideshows ignoring Windows display scaling
Post by konceal »
After I installed v1.4.2, I have the same problem.
Slideshow is not be full screen with Windows 150% scaling.
rhiordan
Post by rhiordan »
This seems also to be the case on Mac OSX Ventura 13.2
27" iMac - all slideshows oversize the window irrespective of setting (full screen, specific resolution, etc...).
V 1.4.2 64-bit (24 January 2023)
Does NOT present in V 1.4.0.
gordol
Post by gordol »
gordol wrote: Sun Jan 29, 2023 9:12 pm I have not tried this on my Win11 nor Win10 desktops, though both of those are set to 100% scaling.
I have tried it on the Win11 desktop, at 100% display scaling, and it works properly.
gordol
Post by gordol »
This is still happening on scaled Windows displays with XnView MP Windows Version 1.4.2 64bits (Jan 23 2023). Update check shows this is the current version.
gordol
Post by gordol »
xnview wrote: Mon Feb 27, 2023 9:54 am This problem is supposed to be fixed in XnView MP 1.4.3. Please check and confirm the bug fix here.
It is fixed. Thank you.
