Previews: how to keep the magnification
artsi
Post by artsi »
1.3.1 appimage on debian
I have a wide hd monitor, so I use the layout 7.
I often shoot bursts @7fps, especially with running dogs, for 6sec to 10sec. This gives me between 30 and 70 images. I'd like to check the focus of the dogs or the position of the ears while the dog is running. Usually, I check at around 50%.
When I switch from one image to the next, it goes back to the 'fit the window' size. Is there a way to keep the magnification between images.
Thanks
Re: Previews: how to keep the magnification
artsi wrote: Wed Feb 01, 2023 5:45 pm Is there a way to keep the magnification between images.
You could try View > Lock zoom if you haven't already done so, not sure whether that will work for your situation...
artsi
Post by artsi »
cday wrote: Wed Feb 01, 2023 5:55 pm You could try View > Lock zoom if you haven't already done so, not sure whether that will work for your situation...
Perfect :D , exactly what I was looking for
Thank you
