[feat] edit palette - cannot set transparency to multiple indexes
XnViewMP 1.4.2
Viewer - Edit palette dialog
Issue
It is not possible to set transparency to multiple indexes at once.
No matter how many indexes you go through with ticking checkbox, transparency will be applied only to the last one.
It shall be possible to set transparency to as many indexes as required, and they applied all to image when OK button is pressed.
Re: 1.4.2 - edit pallete - cannot set transparency to multiple indexes
8bits palette support only 1 index
xnview wrote: Fri Feb 03, 2023 1:45 pm 8bits palette support only 1 index
What about test_png_B.png, is it still valid 8bit png?
TweakPNG allows to edit alpha channel of individual color.
Also note the handy indicator of transparency in TweakPNG (red oval on x scale under each color)
Related
updated previous post with example
user0 wrote: Fri Feb 03, 2023 2:08 pm TweakPNG allows to edit alpha channel of individual color.
yes but not supported by XnView
it would be handy to have such support one day :D
