Unpleasant Display issue
Post by Hakim Antoine Said »
Hello everyone :wink:
when i want to display a picture in window it looks good, when i display in full screen it gets unset even if i set it right it still looks bad in full screen, and when i display in window again it looks all wrong even if i set it right , this BUG is unpleasant and makes XnView MP an useless software :shock:
I love this software but this BUG is unbearable and Unpleasant, PLEASE fix it :(
I go to properties and I configure it to be seen in the window and in full screen the way i want, but when I view it in the window (it looks different from how I put it to see it), the same thing happens when I see it in full screen (it looks different from how I put it to see it)
I set it one way but it looks another way, totally Unpleasant! :evil:
Hugs Everyone and thanks for XnView MP, but this bug is really Unpleasant!
can't be used like this :(
now i am using the viewer that comes by default in windows :x
Last edited by Hakim Antoine Said on Sat Feb 04, 2023 9:21 pm, edited 1 time in total.
Always Keep Going :wink:
Re: Unpleasant Bug For XNView MP
Hakim Antoine Said wrote: Sat Feb 04, 2023 9:02 pm when i want to display a picture in window it looks good, when i display in full screen it gets unset even if i set it right it still looks bad in full screen, and when i display in window again it looks all wrong even if i set it right , this problem is unpleasant and makes XnView MP a useless program :shock:
I love this program but this problem is unbearable and Unpleasant, PLEASE fix it :(
Welcome!
Are you able to illustrate the issue using screenshots, or in some other way describe the issue in more detail?
That would probably be for someone else to hopefully respond.
cday wrote: Sat Feb 04, 2023 9:11 pm
Welcome!
Are able to illustrate the issue using screenshots, or in some other way describe the issue in more detail?
Hello, thank you very much for answering.
I think I was very clear in my words, in the same way I will show proof
Please give me a few minutes and I'll show screenshots
thanks in advance for your answer
Re: Unpleasant display issue
First registration I think today from Columbia, but there is a British saying that 'A picture is worth a thousand words'... :D
Edit:
There is also the question of the menu View > Auto image size setting that you are using, and also possibly some Tools > Settings... settings which you might like to look at, although those should not result in corrupted image display. Your screenshots could be very helpful, but as I indicated probably for someone else.
Re: Unpleasant Display issue
If you have been using XnView MP for some time, and think this is a new issue, you can download earlier versions to test or use from this link.
cday wrote: Sat Feb 04, 2023 9:50 pm If you have been using XnView MP for some time, and think this is a new issue, you can download earlier versions to test or use from this link.
I have the most recent version
the bug exists
AND... old versions does not make sense to use
Last edited by Hakim Antoine Said on Sat Feb 04, 2023 10:17 pm, edited 1 time in total.
cday wrote: Sat Feb 04, 2023 9:21 pm First registration I think today from Columbia, but there is a British saying that 'A picture is worth a thousand words'... :D
Edit:
hello
thanks a lot for replying
BUT... what you wrote, it doesn´t work
and screenshots are on the way!
I'm going crazy with this bug
I gave up, I have tried everything and nothing, the bug exists, i did everything and nothing solve the bug
I am about to delete XnView, if this is not resolved and the problem persists, I immediately delete XnView
such a problem does not make sense to use this software
i love XnView MP, BUT... this Bug is Unpleasant at all!
impossible use it like this!
everytime i have to use shortcut (asterisk) for showing correctly the image, absolutely Unpleasant at all!
full Screen is shown correctly, BUT...
but in normal view, the image looks small, it is not seen in normal size, and I have to press asterisk to see it at 100%
waste of time and completly Unpleasant!
it shows me 21%, and not 100%
like i told you before
in full Screen is shown correctly, BUT...
THIS IS THE PROBLEM... WHEN I SEE IT IN A WINDOW, AND AFTER I PUT IT IN FULL SCREEN, WHEN I WANT TO PUT IT IN A WINDOW AGAIN, THE IMAGE GETS SMALL, THAT IS THE PROBLEM (THAT IS THE BUG), WHEN I RETURN FROM FULL SCREEN, THE IMAGE GETS SMALL AND I HAVE TO PRESS THE KEY (ASTERISK), DOING THAT, THE IMAGE RETURNS TO ITS DEFAULT RESOLUTION!
PLEASE HELP!
I don't know the answer, this is one for Pierre the developer of xnview software, or any other volunteer who might be able to help.
I am normally in Linux, and if your issue is that the View > Auto image size setting is not being remembered, I might have been seeing something similar recently, but I don't have time to investigate. Are using Windows, and if so which version?
You could look at Tools > Settings > Integration tab and see where your .ini file is located: if it is currently in User (Program) you could try moving it to User (System).
Otherwise, you could try testing an earlier versions such as 1.0 to see if the issue is there, I posted the download link above.
so if in understand you correctly, you would like to view image in fullscreen (Fit image to window), and 100% when you return in normal view, right?
xnview wrote: Sun Feb 05, 2023 2:03 pm so if in understand you correctly, you would like to view image in fullscreen (Fit image to window), and 100% when you return in normal view, right?
Hi Pierre :wink:
My Respects For Your SoftWare :!:
YES, THAT´S RIGHT :!:
What You Wrote is Right
SO... When i Return To Normal View After Full Screen, The image Gets Small And Not 100% Size, That´s A Bug, And i Need To Fix That PLEASE :wink:
Last edited by Hakim Antoine Said on Sun Feb 05, 2023 7:46 pm, edited 1 time in total.
cday wrote: Sun Feb 05, 2023 9:24 am I don't know the answer, this is one for Pierre the developer of xnview software, or any other volunteer who might be able to help.
THANK YOU cday, you are a great person, i´m on windows 10, and YET NOTHING fix the bug!
This Bug is Driving Me Crazy, i Mean it, Literally Unbearable And Unpleasant :evil:
i Would Love Keep Using XnView MP, BUT... i Can´t Use it Like This! :(
i Hope it Gets Fixed As Soon As Possible Please, Thanks in Advance! :wink:
