- Make sure info are visible on fullscreen mode
- Open an image in fullscreen mode.
- "F12 > View > info".
- Change some settings then OK : Info display is updated on the current image. Expected
- with arrow key, change image displayed
=> Info has gone. user has to exit fullscreen mode then go back to it to be able to see updated info for all images. Info should not have disappeared
1.4.2
Thanks for listening
[Fixed] Fullscreen Info won't stay if edited while in fullscreen mode
Re: Fullscreen Info won't stay if edited while in fullscreen mode
do you use 'Always in fullscreen'?
Yes I use it, but this is not intentional.
I just tested: Info display will be lost even if the option is not activated.
Making some test to reply to you I have now info displaying in view mode even if image is not fullscreen
are you able to reproduce the problem?
2. open any image in Viewer mode
3. press f11 to switch into Fullscreen mode
info will appear
4. press f12 to open Settings
5. press esc to close Settings
6. press <- or -> to goto prev/next file
info will dissapear, it appears again when i is pressed
info will appear
Confirmeduser0 wrote: Mon Feb 27, 2023 5:43 pm To reproduce:
info will appear
Issue fixed.
Thanks for the good work !!
