XnViewMP 1.4.2 64bits
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Batch convert
Convert button is not active when image loaded via Preview's context menu.
Maybe this is a feature, but image loading selector is quite strange options for the context menu of Preview subtab of Actions tab.
2. press ctrl+u to open Batch convert
make sure there are no files selected in Input tab
3. goto Actions, right click on Preview and press 'Load image...'
4. select any image in Open dialog
Image is loaded, but Convert button is not active
Related
[feat] - batch convert - Convert is not active when Image loaded via Preview context menu
Re: 1.4.2 - batch convert - Convert is not active when Image loaded via Preview context menu
'Load image' is only to choose image in preview, the input file list stay empty
