B2: Minor: Labels are missing for new video file(s)
Locked
Dreamer
Post by Dreamer »
- rename xnview.ini
- switch view to thumbnails and labels
- create new folder (F7)
- place one video file there
- select this file
- press ctrl+c, then ctrl+v
- new file (copy) is created, but..
= name and other labels are missing
The same with folders (use subfolder instead of video file)
Re: B2: Minor: Labels are missing for new video file(s)
Dreamer wrote:- rename xnview.ini
- select this file
Right
Xyzzy
Post by Xyzzy »
For me video files are fixed, bur problem still persists for folders.
X.
Xyzzy wrote:For me video files are fixed, bur problem still persists for folders.
You have no name?
Xyzzy
Post by Xyzzy »
Yes, exactly.
X.
Dreamer
Post by Dreamer »
X.
Right, confirmed.
Another (minor) problems:
- [..] item displays just [.] :bug: #1
- [..] item displays nothing [ ] if you press ctrl+c and ctrl+v on any video file/folder :bug: #2
Xyzzy
Post by Xyzzy »
Dreamer, how to reproduce your last 2 problems? For me filelist is refreshed OK.
X.
Dreamer
Post by Dreamer »
Xyzzy wrote:Dreamer, how to reproduce your last 2 problems? For me filelist is refreshed OK.
X.
Just test folders again and watch the first [..] item. Switch to other view to see how it should looks.
Dreamer
Post by Dreamer »
Fixed.
Closed.
Locked
