1.4.2 Win64 - Info Filename missing Extension
ckit
Post by ckit »
XnViewMP Default Info Fields:
{File Index} - {Filename}
{Format} - {Size KB} KB - {Width}x{Height}
({EXIF:Date Taken}) ({EXIF:Make}) ({EXIF:Model}) ({Zoom}%)
({Tag status}) ({Rating}) ({Color label})
{Filename} is being treated as {Filename without extension} when viewing images in Fullscreen, no file extension is being displayed!
Re: 1.4.2 Win64 - Info Filename missing Extension
{Filename} shows without extension, you need to use {Filename With Ext}
ckit
Post by ckit »
Thank you, that works however this needs correcting...
ckit wrote: Mon Feb 13, 2023 7:07 am Thank you, that works however this needs correcting...
+1, if I undestand you correctly
user0 wrote: Mon Feb 13, 2023 8:14 am
yes but why correcting?
xnview wrote: Mon Feb 13, 2023 9:39 am yes but why correcting?
to improve perception of information
- it will be easy to mentally match menu item and tag
- utilize direction of complexity (from simple to complex), top item shall have short name, next one more complex, etc.
- also it is better to add functionality, rather than subtract (with/without)
ckit
Post by ckit »
Yes, user0 understands my post
Thank you, user0
ok, i'll change
ckit
Post by ckit »
Thank you, Pierre
the same renaming should be done to Output filename
(can be seen eg in Batch convert > Actions > Text)
