1.41 - 1.42: No space for numbers in export quality settings
hlloyge
Post by hlloyge »
XnView: MP 1.41 and 1.42 64 bit
OS: Windows 11 64bit
When exporting picture to webp format, and selecting compression ratio with slider, on the right there are numbers that correspond to slider position. The box that numbers are in is too small and numbers are hard to see. Other export file types are OK
Effect: Display glitch
1. Open image in editor
2. Select Export, select webp format
3. The number is too small
Re: 1.41 - 1.42: No space for numbers in export quality settings
known issue, supposed to be fixed in upcoming 1.4.3
1.4.2 Win64 - Export WebP Percentage GUI Bug
