1.4.2 - viewer - histogram context menu does not appear
XnViewMP 1.4.2 64bits
Windows11 64bit (22H2), display resolution 3840x2160, win scaling 150%
Viewer
right mouse click does not work on histogram with some images
2. open test image 3. press H to show histogram
4. press right mouse button on histogram to invoke context menu
no context menu appears
Viewer
Re: 1.4.2 - viewer - histogram context menu does not appear
I can't reproduce, even with clean .ini
No disrespect but I can reproduce with a dirty .ini but only with "TEST_IMAGE_plane_8_gray.png"
i have few more images with the same effect, if it will help
ok, right its a colormap image, so you can't change histogram view
if it does not take much time the following approach would look better than just disabling context menu,
since there are some other menu items remain on histogram
fixed in 1.4.3
the only issue - it is possible to have situations like on picture below as histogram memorizes it's state
fixed in 1.4.4
