i was looking for a Shortcut for "Save Selection", and i didn´t find it
is there a shortcut for "save selection"
i think it´s very important that option had a shortcut as well, does have it or not
Thanks in advance for everything
HaHaHa i got crazy, i wasn´t in Viewer, i was in Browserwinnylinny wrote: Thu Feb 16, 2023 7:59 pm Tools -> Settings -> Interface -> Shortcuts -> select Viewer -> assign shortcut to "Save selection..."
Shortcut can be assigned, but unfortunately I don't find the "Save Selection" and "Save As" commands in the context menu. I often use these functions and I really miss them in the context menu...Hakim Antoine Said wrote: Thu Feb 16, 2023 7:45 pm i was looking for a Shortcut for "Save Selection", and i didn´t find it![]()
i made this screenshot for you, very easy to understand and this solve your problem broadrem85 wrote: Thu Mar 02, 2023 9:52 amShortcut can be assigned, but unfortunately I don't find the "Save Selection" and "Save As" commands in the context menu. I often use these functions and I really miss them in the context menu...Hakim Antoine Said wrote: Thu Feb 16, 2023 7:45 pm i was looking for a Shortcut for "Save Selection", and i didn´t find it![]()
@adrem85 was referring to something else: the right-click context menuHakim Antoine Said wrote: Thu Mar 02, 2023 7:55 pm i made this screenshot for you, very easy to understand and this solve your problem bro
LOLwinnylinny wrote: Thu Mar 02, 2023 8:00 pm@adrem85 was referring to something else: the right-click context menuHakim Antoine Said wrote: Thu Mar 02, 2023 7:55 pm i made this screenshot for you, very easy to understand and this solve your problem bro![]()
