For example, when deleting a photo, the list of thumbnails is updated immediately.
But when a filter is applied (for example, I'm filtering out uncoloured photo), then once a new photo is assigned a colour, that photo should "disappear" from the current filtered view -- but it does not for me. So I have to click the filter menu, select the "Uncoloured" again to update.
Is there an option to achieve this?
Thanks!
Live update of files while filtering
Re: Live update of files while filtering
it's a known issue
