we need to install XnView on several machines. The tool of choice for us is Intune. Packaging the software is not a problem in itself. However, I would have to be able to give it the settings directly (in particular the storage as a registry entry) that I make in the "first programme start" screen. Including the information that this screen will then no longer be displayed.
Is there a way to do this?
Best Regards,
Nene
First programme start: Set settings automatically
neneatmuc
Re: First programme start: Set settings automatically
you can create basic settings in registry and copy keys to install on other machines?
