OSM as map option
MartinX
OSM as map option
Post by MartinX »
It would be a dream if you could change the map from Google Maps to OpenStreetMap (OSM) for the position view. OSM maps are much more detailed off the road.
Re: OSM as map option
with 1.4.3, you can use osm as map
gpsProvider=osm
cicciobello
Post by cicciobello »
Works in [%General].
Good!
MartinX
Post by MartinX »
Thanks to both of you, it works :-)
Post by michel038 »
- Added gpsProvider=osm in [General] section
- still Google maps ... :|
Edit Some days later :
Thank you Ciciobello (see next post)
[%General] section added with gpsProvider=osm
... it's OK
In View mode, right click, proprties, GPS tab is still with Google maps
For now, it's a good thing, so that I can use the one that gives best results.
cicciobello
Please try [%General].
