improve readability of -help output by alighning it to grid
main change
- -help output aligned to grid
other changes
- unifed period marking to ... (tripple dot) as there are 3 different symbols used: <->, -, and ...
- unified channels naming to short version (r g b a), as sometimes it is written in full, sometimes in short
- fixed some typos in description:
-- "Display informations only" > "Display information only", information sould not be plural
-- "Display information & metadata only" > "Display information & metadata only", same as above
-- "Geometry is widthxheight+offset" > "Geometry is WidthxHeight+Offset", capitalize for better readability
-- "floydSteinberg" > "Floyd-Steinberg"
-- added space after comma
-- deleted space before : in some cases, e.g. "(default : 6)" > "(default: 6)"
-- deleted space in the end of most lines
to check
- "Album bщbщ", not sure if this is correct description for frm2 extention
UPD
230312
- minor fix: "AVIF speed (0-10)" > "AVIF speed (0...10)"
[suggestion] Align -help output to grid
- Attachments
- -help_7.136_new_230312.zip
- (11.23 KiB) Downloaded 36 times
Re: [suggestion] Align -help output to grid
Good effort, but I have a problem with character encoding after:
Asian characters, I think?
-jxr_filter value : JpegXR block filtering
0 : off
1 : HP
2 : all
hm, it was UTF-16 LE (generated by win cmd via >), resaved as UTF-8
hope that helps
hope that helps
Fixed now, thanks.
Having used NConvert in Windows today, and having been reminded that the % character must be doubled to escape the character, I am wondering whether the following NConvert help file entry might be usefully edited to include a reminder:
Or something similar?
Are there any other characters used in NConvert that also need to be 'escaped'?
-o filename : Output filename
Use # to specify position of numeric enumerator
Use % to specify source filename (In Windows use %%)
not sure why this topic is in Closed/Resolved
OP issue is still there
also related:
short form of inch shall be 'in' not 'i'
also related:
