I'm trying to convert a TIFF to JPEG format, but nconvert seems to erase the EXIF data... is this the normal behaviour?
You can take an example TIFF here.
The command line I use is the simplest:
C:\noinstalls\nconvert\nconvert -in tiff -out jpeg CRW_3960.TIF
Any help appreciated.
Keep losing TIFF EXIFs....
Re: Keep losing TIFF EXIFs....
Currently EXIF in tiff file are not readed...guest wrote:Hi,
Thanks for your answer. Do you plan adding it?xnview wrote: Currently EXIF in tiff file are not readed...
PS.I did wrote you privately yesterday, sorry for bothering you but I didn't see the link to the forum!
Yes, i'll add itAnonymous wrote:Thanks for your answer. Do you plan adding it?xnview wrote: Currently EXIF in tiff file are not readed...
