Batch convert - output - improve information readability
XnViewMP 1.4.3 64bit
Batch convert
improve output readability
Suggestion A - plain text
  • use symbols
    - mainly to display status (there are few different tick marks and crosses available)
    - maybe replace some other symbols (eg arrow)
  • align text to grid with spaces/tabs
    - mainly text in summary. Aligning Image details and Comment do not worth the hassle.
☑️ D:\PROG\feedback\xn\_test\_files\test1.png 500x500x4    : loaded
✅ D:\PROG\feedback\xn\_test\_files\out\test1_result.png   : saved
673 Bytes ➡️ 35.22 KiB	5259%
❌ D:\PROG\feedback\xn\_test\_files\excel_file.xlsx 0x0x0  : not a picture
✔️ D:\PROG\feedback\xn\_test\_files\test2.jpg              : loading***
✔️ D:\PROG\feedback\xn\_test\_files\test2.jpg 3264x2448x24 : loaded
✔️ D:\PROG\feedback\xn\_test\_files\out\test2_result.jpg   : saved
2.79 MiB > 1.11 MiB	-60%
✔️ D:\PROG\feedback\xn\_test\_files\test3.jpg 3264x2448x24 : loaded
✔️ D:\PROG\feedback\xn\_test\_files\out\test3_result.jpg   : saved
-60%	2.79 MiB → 1.11 MiB
Input files     : 3
Extracted pages : 2
New files       : 2
Overwritten     : 1
Total input file size  : 2.79 MiB
Total output file size : 1.14 MiB
File size ratio        : 58%
Started at     : 2023-03-05 9:54
Finished at    : 2023-03-05 9:54
Total Duration : 0 second(s)
*** not sure if 'loading' is still in use as I only saw it on some screenshots
Suggestion B - table
  • rework into table structure add html support
    (can be a checkbox in settings [plain/html output])
    to expand formatting capabilities to:
    - table structure
    - text weight (eg highlight changes in bold)
  • Summary can be grouped
Example
  • ACDSee Batch edit
Related
Re: Batch convert - improve output readability
Please check next release, i have improved it
