3D Border Effect issue
Post by Hakim Antoine Said »
Hello Every1 :)
when i make a selection and i want to use the 3D border effect, it doesn't apply the effect to the selection, it applies the effect to the whole image, that's a bug :(
i use a lot this effect
Always Keep Going :wink:
Re: 3D Border Effect issue
Hakim Antoine Said wrote: Thu Mar 09, 2023 7:05 pm i use a lot this effect
in what app?
I do not see border effect can be applied to the selection in acdsee, irfanview or faststone
However, this feature request is quite interesting.
Not sure how it will work with round and free-form selection if Pierre decides to add them one day.
in what app?
irfanView has that option, and i use it almost everyday, I make a selection and irfanView applies the effect to that selection
XNView MP has that option as well, BUT the effect does not apply to the selection, it applies to the entire image, and that´s the bug
xnview wrote: Mon Mar 13, 2023 1:18 pm :bugconfirmed: Thanks to your detailed description I can reproduce the problem.
Thank You Pierre :wink:
xnview wrote: Tue Apr 18, 2023 2:55 pm This problem is supposed to be fixed in XnView MP 1.4.4. Please check and confirm the bug fix here.
Hello Pierre :wink:
it fixed
THANK YOU VERY MUCH :)
