thumbnails from Raw (CR2/CR3/NEF) + another question
madz123
Post by madz123 »
Hello
1) I've been looking at old raws recently - but I think Xnview isn't saving thumbnails (from CR2/CR3/NEF). When I re-enter the folder in a moment, it takes a few minutes before my thumbnails, for example, from 500 photos, appear. Is it true?
2) how to make it so that when you press alt+enter both in thumbnail view and in full screen the same menu is displayed? I want it with Xnview, not system. I've already asked this question in the bug forum, but I still have the problem. (I'm attaching a screenshot)
Best regards
madz123
Re: thumbnails from Raw (CR2/CR3/NEF) + another question
Post by madz123 »
ad 1) I answer myself. The problem with creating thumbnails for RAW files disappeared when I changed the saving format from "lossless compression (ZIP)" to "jpg - low quality". incident?
The second thing, I don't know how the access to the thumbnail database behaves when several xnview windows are open that generate thumbnails at the same time?
The information in properties dialog shown in 'edit mode' are in Info panel in browser mode
madz123
Post by madz123 »
this is not the same as classic XnVIEW - the permanently attached info panel takes up space for thumbnail previews.
