Interface > Mouse right click issue on MacOS
Sajjad
Post by Sajjad »
First of all, thank you for creating this great software. I have been using this for many years on Windows and it works flawlessly. Recently, I got MacBook Pro and I have been having an issue with a setting, and I hope there is a way to fix it.
Preferences > Interface > Mouse > Right button > Next file
https://i.gyazo.com/afe8b4b8f1347126b6a ... 6fcefc.png
The problem is that it's showing the context menu on MacOS when I try to go to the next image with the right click. Image changes but the context menu is a huge distraction. Is there any way to fix this?
On Windows, it works fine and I can go to the next image with a right-click without any issue.
Re: Interface > Mouse right click issue on MacOS
which version, it has been fixed in latest version?
