1.4.3 GPS tab is empty
cassowarry
Post by cassowarry »
XnView: MP 1.4.3 - 64 bit
OS: Arch Linux - 64bit
GPS tab on every image with GPS data embedded is empty. Starting XnView MP in the console, selecting an image and switching to GPS tab shows "The geoservices provider is not supported.". A couple of weeks ago it worked but I updated Arch and XnView MP in between to the latest versions.
Effect: GPS tab is empty
1. Start XnView MP
2. Select any image with GPS data embedded
3. Switch to GPS tab
4. GPS tab is empty
Actual behaviour (bug): GPS tab is empty :bug:
Expected behaviour: Map with GPS location is shown
Re: 1.4.3 GPS tab is empty
could you try OSM as map provider
cassowarry
With OSM it works. Great, thank you.
