"Size" category is indented wrong
WhiteGuy
Post by WhiteGuy »
As you can see, the "size" category/parameter is indented wrongly. It's glued to the right side, while every other category is glued to the left. Should be an easy fix.
Re: "Size" category is indented wrong
it's because file size is aligned to right and not left
WhiteGuy
Post by WhiteGuy »
xnview wrote: Mon Mar 20, 2023 1:30 pm it's because file size is aligned to right and not left
Yeah... I know. That's why i made the post. Is it something that will be fixed in the future?
WhiteGuy wrote: Mon Mar 20, 2023 1:56 pm Yeah... I know. That's why i made the post. Is it something that will be fixed in the future?
there is nothing to fix
change 'View as' to 'Details' and you will see why it is aligned to the right
WhiteGuy
Post by WhiteGuy »
user0 wrote: Mon Mar 20, 2023 2:15 pm
Why not program it so it changes alignment when the view is anything other than "Details"? It looks very out of place in the thumbnail views.
