Panning an image all the way to the left produces glitch
WhiteGuy
Post by WhiteGuy »
If i zoom in on an image (a big one) and pan to the left then it shows the wrong part of the image.
Look at this example.
The screen is correctly showing the part of the picture that i've zoomed in at.
But look what happens when i pan all the way to the left. The screen shows a wrong part of the image. This only seems to be an issue on highres images.
Re: Panning an image all the way to the left produces glitch
could you send me your image file?
WhiteGuy
Post by WhiteGuy »
here you go, naughty boy
https://i.imgur.com/B6yxnP8.jpg
i can't reproduce, do you use Windows scaling?
WhiteGuy
Post by WhiteGuy »
xnview wrote: Mon Apr 03, 2023 1:33 pm i can't reproduce, do you use Windows scaling?
nope, no other scaling than what happens when i zoom further than 200%
It happens on all images where your zoom window is smaller than the width of the entire image.
i means Font scaling in Windows Display Settings?
WhiteGuy
Post by WhiteGuy »
I got the font at 100%, but the "change size of apps and text on display" is set to 125%.
Changing it to 100% doesn't fix the issue.
WhiteGuy wrote: Tue Apr 04, 2023 8:19 am Changing it to 100% doesn't fix the issue.
With 100%, always the problem??? even after restarting XnView
WhiteGuy
Post by WhiteGuy »
xnview wrote: Tue Apr 04, 2023 8:48 am
Yep, the problem persists even when setting is set to 100% and XnView is restarted
there is definetly some issue (split into separate post), but I cannot reproduce at 100% win scale
I can confirm but if you restart XnView after changing setting, it works correctly
WhiteGuy
Post by WhiteGuy »
xnview wrote: Fri Apr 07, 2023 9:34 am I can confirm but if you restart XnView after changing setting, it works correctly
It doesn't for me. I set "size of text, apps, and other items" to 100%, then closed everything, restarted my PC, opened up XnView, and the problem is still there.
in your screenshot, the view is strange, it's normal??
what do you have in Settings>View?
WhiteGuy
Post by WhiteGuy »
xnview wrote: Fri Apr 07, 2023 10:16 am in your screenshot, the view is strange, it's normal??
What do you mean? It's not normal, it's broken. Everytime i pan all the way to the left, the image shows a bit of the right side of the image.
Here is an album with my settings: https://imgur.com/a/SMxBHKr
i can't reproduce, please send me your xnview.ini?
