Folder preview image smaller than image preview on 4K display
dp792
I have a new 4k display, I set the resolution to 2560*1440 and now the size of the folder sketch is smaller than the size of the picture sketch
Re: Folder preview image smaller than image preview on 4K display
even if you rebuild them?
dp792
After rebuilding, the same thing
Dmitri
Dmitri
dp792
there is such a thing and rebuilding doesn't change anything
the selected folder is bigger?
dp792
It doesn't matter
Dmitri
Dmitri
