incorrect color at 100% viewing
xnviewuse
Post by xnviewuse »
as shown in the attachments, the picture looks ok when zoomed in or out
when viewed at 100% (or * pressed), the color is incorrect
xnviewuse
Re: incorrect color at 100% viewing
Post by xnviewuse »
please check the photo file attached
xnviewuse
Post by xnviewuse »
please check the photo file zipped
masterjp
Post by masterjp »
Hello, I tested your picture with XnviewMP 1.4.3 on Windows 10 64bit (latest updates) and could not detect any problems.
Maybe it is a problem of your operating system, graphic driver (old version) or something else!?
spleen
Post by spleen »
Intel i7-10700, GTX1650S 4GB, 32G RAM
OS: Win10 Home 22H2, XnViewMP 1.4.3 64bit
masterjp
Post by masterjp »
Thank you for the video. I read your older posts from 2022. You had some other color issues in the past with other jpeg files, too.
Maybe you can test the same situation again with a XnViewMP portable version, too.
It uses the standard settings and a fresh folder with all required files.
what do you have in Settings>View? And do you use ICC profile?
spleen
Post by spleen »
The issue remains whether or not an ICC profile was used.
Another interesting observation is that when I saved the JPG file to either a PNG or TIF format, the issue still existed.
spleen wrote: Wed Mar 29, 2023 1:26 pm The issue remains whether or not an ICC profile was used.
Really strange, could you send me the png?
spleen
Post by spleen »
I tested the picture (med1) on different PCs.
incorrect: MSI (Intel i5-6400, NVIDIA GTX960)
incorrect: MSI (Intel i5-8400, NVIDIA GTX1050)
incorrect: MSI (Intel i7-10700, NVIDIA GTX1650S)
ok: ASUS (Intel i7-7500U, NVIDIA 940MX)
Weird enough, it's ok for med2.jpg for all PCs.
and if you use bilinear as resize method?
spleen
Post by spleen »
I tested the different zoom quality options:
bilinear, bicubic, spline16, spline36, lanczos3, lanczos4
bilinear: incorrect image at initial 100% viewing
the remaining 5 methods: initial 100% viewing ok -> incorrect after zoom in->zoom out /or/ after zoom out->zoom in
if you change 'pixel ratio' always the problem?
spleen
Post by spleen »
my default 'pixel ratio' is "D1/DV PAL (1.07)"
after I changed it to "square", wow, the issue is gone!
spleen wrote: Wed Apr 05, 2023 1:19 pm my default 'pixel ratio' is "D1/DV PAL (1.07)"
Ok, strange, i'll try to reproduce...
