The "Lock Zoom" shortcut does not work (cmd_lockZoom)
Also the set shortcut is not shown in the View menu (as opposed to other set shortcuts), and could be related to the issue.
The Lock Zoom shortcut is however stored/remembered in the settings.
The View menu command "Lock Zoom" is honored for the current session, until I close XNViewMP.
Version Windows XnView MP Windows Version 1.4.3 64bits (Feb 25 2023)
for me it looks like there are two "Lock Zoom" commands, one for the Settings, another for the View menu.
because, aside its shortcut setting not working, "Lock Zoom" does not have an icon in the Settings, but in the View menu command "Lock Zoom" does have an icon, and the set shortcut is not shown in the View menu (as already mentioned).
Additionally, "Look Zoom" cannot be preset in the Settings.
Peter.
lock zoom shortcut not working
Re: lock zoom shortcut not working
'Lock zoom' in browser or edit mode?
Peter26mar2023
I didn't notice that there are two distinct registers for keyboard shortcuts: "Browser" and "Viewer", which has to be selected via popup in the Presets. After noticing this popup-control, it works as expected.
Thanks for the help.
I'm not sure to write the following, maybe I do not understand. I was'nt aware of the other "Lock Zoom". It seemed one command (cmd_lockZoom) and not two, say cmd_lockZoom_Browser, cmd_lockZoom_Viewer and so on. It seems one command, but the shortcut distinguished, and icon-handling in the menu also distinguished for same command (cmd_lockZoom).
