How to rotate the picture and save it directly?
johnmy
Post by johnmy »
hello there
When I rotate the picture and press next button, the application will prompt me to save the changed file or not, can it be saved without prompt after I rotate the picture and press next button.
The applicaiton I used:
XnView MP Windows
Version 1.4.3 64bits (Feb 25 2023)
Any suggestions?
Thanks.
Re: How to rotate the picture and save it directly?
you can change in xnview.ini
savingChanges=1
johnmy
Post by johnmy »
It works.
Many thanks.
