Missing filename when viewing photos from Nikon P900
Ph0t0
Post by Ph0t0 »
in 'Information Display', the file name is not displayed for photos from certain cameras.
This applies to the Nikon P900 and some Olympus cameras.
XnView Classic works fine.
XnView MP - Filename missing
XnView Classic - Filename shown
View Settings
View Settings
Re: Missing filename when viewing photos from Nikon P900
Right it's a bug in Qt library. A workaround is to put 'User comment' below or put an extra character after 'User Comment'
{EXIF:Date Taken [Y-m-d_H-M-S]}
{EXIF:User Comment}.
{Filename With Ext}
Ph0t0
Post by Ph0t0 »
Thank you Pierre,
I hope, it will be fixed in a future version.
Until then I can live with it. It only affects the unaltered photos as they come out of the camera.
As soon as I insert EXIF User Comments (with the program InfoGucker) the file name appears.
Ph0t0
Post by Ph0t0 »
The problem is fixed in XnView MP 1.4.4
Thank you very much.
