AVIF image open failed
JesOb
Image from nintendo site can not be opened while firefox can open it
Image itself in attachments
Re: AVIF image open failed
no problem here, on windows?
Kadet
XnView: MP 1.4.3 - 64 bit
Windows 11 Home 64bit 22H2
I can not open animated avif.
I can't do it from Windows Explorer --> "open with" --> XnView MP.
In browser window XnView some time I see this files, some time not. When I see animated avif I can not open it by double click or right click (Open function is gray). I always see other avif images in browser window.
Examples You make here: ezgif.com/gif-to-avif
ckit
I can't confirm with XnViewMP 1.4.3 or IrfanView 4.62 (Windows 11 Pro x64 22H2 and HEIF image extensions)
xnview can open it if I manually navigate to the file via browser and doubleclick it
otherwhise.. there is issue with assosiation
1. I select XnView MP, press Always
2. doubleclick on image
xnview opens in browser mode with last openned folder
also icon in file explorer
no problem here, please check the registry entry?
ckit
Windows 11
Open Settings app -> Apps -> Default apps -> "Set a default for a file type or link type" type ".avif" and hit Enter
it does not helpckit wrote: Mon Apr 03, 2023 12:51 pm Windows 11
it is required to manually change regisrty, adding %1, for example:
from
[HKEY_CURRENT_USER\Software\Classes\avif_auto_file\shell\open\command]
@="\"D:\\PROG\\portable\\graphic\\XnViewMP\\xnviewmp.exe\""
@="\"D:\\PROG\\portable\\graphic\\XnViewMP\\xnviewmp.exe\" \"%1\""-
yes, strange that Windows doesn't add it...user0 wrote: Mon Apr 03, 2023 1:56 pm it is required to manually change regisrty, adding %1, for example:
the issue is quite old and happened with multiple extenetions
Double-clicking on OpenEXR file has no effect
I also experienced it with .jfif
yes, but it's not XnView. registry entry is added by Windows
Kadet
Pierre - do You confirm this bug?
When I open XnView I don't see animated avif files in browser window (top half attached image).
When I open some image and next I close browser tab, and next I click to open the browser tab I see animated avif files (bottom half img). But I can not open this avif.
Non animated avif I see, and I can open that files.
animated avif is not supported
