hello,
I apologize in advance if that has been asked before.
Is it possible to have the small preview (under the file browser) that uses the RAW embedded image (very fast).
But, when double-clicking on the image the View in Tab shows the full RAW image?
I tried
- Settings > View > Camera RAW, use "Full size" but even in the preview it loads the full image (slow)
- Settings > View > Camera RAW, use "Embedded preview" but then in the full image view, it shows the smaller embedded image
Or maybe it's possible in `~/.local/config/xnviewmp/vnview.ini` ?
RAW, use embedded for Preview, real for View
Re: RAW, use embedded for Preview, real for View
Currently there is no way to use 'embedded preview' in preview and 'full size' in image view
