Problem with crop tool [Solved]
petejack
Post by petejack »
Hi, I cannot select the crop tool in any version of XnView. When a photo is opened to the edit page initially the crop tool is highlighted, but as soon as I select it, it greys out. I have tried reverting to earlier versions with the same results. Must be a setting somewhere as I have XnView installed on another PC (which I don't have access to at present) and the crop works fine. It's possible that something could of changed during an update. Any ideas,
Thanks Pete.
Re: problem with crop tool.
do you select a rectangle?
petejack
Post by petejack »
Hi, Thanks for the reply. Yes I found that none of my mouse buttons were set for 'make selection'. All good now.
Thanks.
