Add support for more .dds texture compression formats.
Moff
Post by Moff »
More specifically, BC4 and BC5 compression, which is fairly common in modern video games.
The problem i have is not just that XnView doesn't open .dds files in these formats, which is unfortunate, but i have other programs which can do that, but if you have XnView's browser set to only display image files, and then open a folder containing these .dds files, XnView would try to generate a thumbnail for them, fail, and then instead of showing them without a thumbnail, it will hide them altogether.
Which, if you use XnView to browse images instead of your os browser, like i do, it can get really confusing, as i might be looking through folders, searching for a certain file, and think "oh well, i guess the file's not here", when it is and it's just been hidden.
I really hope that support for those formats can be added in future releases, or at least implement some way to change the behavior i described above where failure to display a file with an extension of a known image format excludes it from the list of files shown to user.
Re: Add support for more .dds texture compression formats.
could you send me sample files?
Moff
Post by Moff »
Here you go. And here's a description of the formats: http://sv-journal.org/2014-1/06/en/inde ... ang=en#5-4
Moff
Post by Moff »
Bumping cause i only now realized that XnView actually does support both BC4 and BC5, it just doesn't recognize FourCCs that some of the encoders write. It seems to expect FourCC for those formats to be "BC4U" and "BC5U", while they could also be "ATI1" and "ATI2" respectively (https://github.com/Microsoft/DirectXTK/ ... tureLoader), as they were in the examples i attached. I tried replacing 4cc in a hex editor, and the file opens up in XnView without any issues.
It you could add a check for those other FourCCs, that would probably be enough to resolve the issue.
