In the table there are items that are not shown in XnViewMP.
EDIT:
It' worse:
Some files are assoziated with the "invisible" categories,
not shown anywhere (except in the db of course).
Category system, SQLite DB, table "Tags"
nji9
Re: Category system, SQLite DB, table "Tags"
Perhaps files removed outside
nji9
No, you do misunderstand.
It's NOT about files, but about categories.
In Xnview.db there are entries in the "Tags" table
that are not seen in XnViewMP anywhere.
Long time ago I removed them.
And even worse:
Due to the "TagsTree" table in Xnview.db
some files are associated with that "no existing" labels!
There is a bug in XnViewMP:
Not showing all category entries that are in the db's table "Tag".
Confirm?
And even worse:
Confirm?
houps sorry. Strange, which column values do you have? Is it possible to have your .db?
nji9
Sent as PM...
just experienced similar issue
A
while working with categories via the UI (creating, renaming, and moving them), I noticed that one of them disappeared (c2).
Record still exists in db, but somehow has ParentID = TagID
Unfortunately, I have not been able to reproduce this issue so far and do not have this db anymore.
B
if there is a record in Tags with ParentID = TagID and 'Update files from catalog is pressed - app stuck with updating dialog
A
B
c2 had which parent?user0 wrote: Fri May 01, 2026 12:42 pm A
yes, it's a problemB
unfortunately, I do not remember
btw, what is the purpose of ID field in Tags table?
currently not used
